Thermionic Effects TE-01 Tube Overdrive
No starved plates here, this is a high-voltage vacuum tube preamp.
Essentially the front-end of a Fender Bandmaster or Showman, it can provide saturating level boost to any tube amp. Indicator LED is blinding-bright so we put tape over it. You can still see it. You could see it through steel diamond-plate.
