Josephson C700a
Two-capsule condenser mic with a rich sound
Dual capsule condenser mic with independent outputs. Both capsules are fixed position. Upper capsule is a small (1/2") pressure (omni) microphone, lower capsule is a 1" bi-direcitonal capsule. In use, the two capsules are bussed together and a synthesized pattern of any shape is made by balancing the two capsules in any ratio. This can also be used to balance the sound qualities of the two capsules. Primarily used for voice, it can be used as an M-S stereo ambient mic or for other timbre-critical uses (string soloists, ensemble area mic, etc.) See Josephson.com for more information.
Not really similar to anything else.
