Calrec Soundfield MK 4
4-diaphraghm mic with control box allowing unique shaping of the pickup and stereo image
Four-capsule microphone. Used with dedicated matrix box, allows stereo image to be manipulated while monitoring in stereo. Image width, vertical angle, 360 degree pan and forward/backward (from the control room position) can all be manipulated. In addition to pattern shape, the spatial manipulation this system makes possible is unique and very powerful. But that aspect aside, this is also a very detailed microphone that can withstand high sound pressure. Useful for drum kit, ensembles, acoustic instrument, area and ambient recording. If the four capsule outputs are recorded separately ("B-Format"), then the depth, width and positioning can be adjusted after recording. The system is slightly noisy, which can be a problem with very quiet sources.
