Altec M20 (165 / 175)
“Lipstick” tube mics
Qty: 4
Qty: 4
Qty: 4
Nickname: "lipstick" ]
(N.B. We refer to this mic as the 175/ 165, which is the preamp/ mic body designation. Altec sold this preamp with a 21-series capsule and power supply as the “M20 microphone system.”
Excellent snare drum mic. Also good for close mic on acoustic string instruments like banjo, guitar, mandolin. Can take very high signal level. Some system noise may make it unsuitable for very quiet recordings.
Model # 175 indicates the mic is set for using the 29A, or 29B (cardioid) capsules.
Model #165 means it is set for 21D, 21A (omni) capsules.
These mics are a slim cylinder, and should only be used in mic clips made for them for reasons of stability. We have some crappy plastic Altec ones and some spiffy aluminum ones made for us by Kristina Bozic.
We have modified some Altec 165s to be used as 175s so they can use the 29A/B capsules. The modification involves the addition of 1 resistor in the microphone cable, and does not affect the sound. Really, it doesn't. Okay, retro snob, you try running a studio for a while. Shut up already.
Similar to: Altec 195, 201, 150, AKG C28, C60, C451
